13 Dec 2024
05:50 PM
16 Dec 2024
07:38 AM
***Yyou need to add an environment url and a token for this!!***
Hello, maybe anybody has use or finds my dashboard handy, it gave me as extra some insights in then 2.0 settings framework.
The dashboard shows all schema and object info
You can select any schema in the selection on top
Giving you a nice schema dump
And all objects in the schema
Adding the scope in the top menu
next a list of object changes
adding the object id on top menu show full json
KR Henk
(code follows)
13 Dec 2024 06:58 PM
PLease download,rename to json and import as Dashboard
