03 Sep 2024
10:51 AM
04 Sep 2024
07:04 AM
I have some DQL that looks at a web servers log files and counts the number of hits on services gives me data in a table like this:
| service_name | status_code | hit_count |
| checkOut | 200 | 1234 |
| checkOut | 404 | 1 |
I would prefer to present it like this so that I can apply percentage calculations and categorise the record as being OK or needing action.
| service_name | 200 | 404 |
| checkOut | 1234 | 1 |
Is there a way to do this kind of thing?
04 Sep 2024 01:52 PM
Unfortunately the only technique I know to get it is via same method you probably saw already:
https://community.dynatrace.com/t5/DQL/DQL-How-to-Flatten-an-Array/m-p/251125/highlight/true#M1073
For your data it would look like:
data
record(serviceName="checkOut", status_code=200, hit_count=1234),
record(serviceName="checkOut", status_code=404, hit_count=1),
record(serviceName="login", status_code=200, hit_count=4),
record(serviceName="login", status_code=403, hit_count=1)
| summarize { d=collectArray(array(toString(status_code),hit_count)) }, by: {serviceName}
| fieldsAdd d=toString(d)
| parse d, "'[' KVP{ '[' DQS:key ', ' LONG:value ']' ', '?}:code ']'"
| fieldsFlatten code
| fieldsRemove d, code
Kris
04 Sep 2024 04:10 PM
Thanks Kris, you are right I did read the other thread. This approach does work fine and is actually quite similar to how I would have approached in in SPL which is where my skillset is coming from.
