27 Feb 2025 07:41 PM
hi all, i am trying to do Monthly Problem Count and ServiceNow Ticket Count Over the Last 4 Months in one tile.
fetch dt.davis.problems
| summarize TotalProblemMonthly=count(), by:{Month = formatTimestamp(timestamp, format: "MM-yyyy")}
| join [fetch dt.davis.problems
| filter matchesPhrase(labels.alerting_profile,"ServiceNow")
| summarize ServiceNowTickets=count(), by:{Month = formatTimestamp(timestamp, format: "MM-yyyy")}], on:{Month}
the result coming out not sorted i want to sort it based on a month, however if i use sort command will not use the year ad well which is a problem. look at the result image. any recommendation to fix the query to sort it?
27 Feb 2025 08:01 PM - edited 27 Feb 2025 08:02 PM
Try putting the year first, and you don't need to do the join.
ServiceNowTickets=countIf(matchesPhrase(labels.alerting_profile, "ServiceNow")),
by:{Month = formatTimestamp(timestamp, format: "yyyy-MM")}
| sort Month desc
27 Feb 2025 08:15 PM
Perfect!, my other question. why it says line graph is unsuitable. if i want the results in graph.
28 Feb 2025 08:18 AM
You should use rounded timestamps, not string representation. Also to do proper bar chart it is better to use timerange so single bar spans the time it applies to:
| summarize { TotalProblemMonthly=count() , ServiceNowTickets=countIf(matchesPhrase(labels.alerting_profile, "ServiceNow")) },
by:{ timeframe=timeframe( from: timestamp@M, to: timestamp@M+1M ) }
| sort timeframe descI used time alignment operators: https://docs.dynatrace.com/docs/discover-dynatrace/references/dynatrace-query-language/operators#tim....
Result look like this:
