27 Jan 2025
10:53 AM
28 Jan 2025
07:00 AM
Hi Team,
I have a requirement to pull down a specific process kept in availability monitoring on my environment and wanted to generate a report and gather info that on which machine availability monitoring is enabled for this specific process. Is this possible to get the data from DQL??
EX: Host A, Process xyz --> getting monitored for availability alerts
Host B, Process xyz --> getting monitored for availability alerts
Host C, Process xyz --> Not enabled for availability alerts
11 Mar 2025 12:17 PM
Hey!
That is not a very straight-forward thing to accomplish, as the process availability monitoring is set through the settings 2.0 and is not a property of a process. There is one thing you could potentially do through DQL - you can look for events that were created when the settings were changed - there is a limitation that you would only be able to get settings that were touched since mid 2024.
Query would look something like this to start with:
fetch dt.system.events
| filter event.kind == "AUDIT_EVENT"
| filter event.provider == "SETTINGS"
| filter details.dt.settings.schema_id == "builtin:availability.process-group-alerting"
| sort timestamp desc
There you'd be interested in the details.json_after to see what was the change made (either disabling/enabling) and details.dt.settings.scope_id where you would find the process group that was changed.
Other than that, I believe environment API v2 has an endpoint that could help you accomplish a similar result but it wouldn't be through DQL.
