DQL
How do I return values which have returned 1?
badgerfifteen
Organizer
I have the following DQL code below:
timeseries interval: 10m, file_count = avg(filesystem.file_count, filter: { ( in(`dt.entity.filesystem:path`, classicEntitySelector("type(filesystem:path),entityName.equals(\"/link/link1/link2/test.csv\")"))) OR ( in(`dt.entity.filesystem:path`, classicEntitySelector("type(filesystem:path),entityName.equals(\"/link3/link4/test.1\")"))) }), by: { `dt.entity.filesystem:path` }
| fieldsAdd entityName(`dt.entity.filesystem:path`)
| sort arrayAvg(file_count) desc
| filter arrayIndexOf(array(file_count), 1)
When using the line chart for the last 24 hours, this will display a line chart where it is mostly 0 and then around 18:00, jump up as the value has changed to 1 until 19:00.
I've tried using arrayIndexOf to filter to just 1, but it doesn't appear to work. Any ideas? How do I filter values or set a threshold to values which only appear as 1?
t_pawlak
DynaMight Leader
DynaMight Leader
After timeseries, file_count is an array (time series), not a single value.
So arrayIndexOf() won’t work as expected.
Use iAny() to filter series that ever had value 1, and [] to work on points.
try change filters To keep only series that ever reached 1:
| filter iAny(file_count[] == 1)
To display only points where the value is 1
| fieldsAdd file_count = if(file_count[] == 1, file_count[], else: null)
try this example:
| filter iAny(file_count[] >= 1)
| fieldsAdd file_count = if(file_count[] >= 1, file_count[], else: null)
it should keeps only series that hit the value 1
