DQL
Looking for DQL to discover maintenance window settings
rseibert1
Guide
Not seeing an ability to query DQL for the maintenance windows that are currently active, besides which entities the window effects. We currently have a workflow that creates new windows but does not activate them (user triggered) so observability team can verify the window looks good and then just through the slider to Active. The trouble with that is I see no way to query to verify this action had taken place.
p_devulapalli
DynaMight Leader
DynaMight Leader
@rseibert1 Can you try the below DQL ?
Take a look at the "details.json_before" and "details.json_after" fields . These would have the info you are after
Hope this helps
fetch dt.system.events
| filter event.kind == "AUDIT_EVENT"
  and event.provider == "SETTINGS"
  and matchesPhrase(details.dt.settings.schema_id, "builtin:alerting.maintenance-window")
Phani Devulapalli
Thanks for this insight, I knew there had to be a way!
