DQL
Nice to know about using arraySize in DQL
henk_stobbe
Leader
May be I am mistaking but when in timeseries using a statements like:
                                             | fieldsAdd newField = arraySize('         ')
It looks like there is a hard limit of 1500. DQL changes the interval to keep below this number....
So as an example using an interval of 1 minute: 24 hours will be 1440 (minutes/points)
        but 26 hours will give 780 (two minutes/points)
KR Henk
@MarcZ
henk_stobbe
Leader
FYI found this:
https://docs.dynatrace.com/docs/discover-dynatrace/platform/grail/dynatrace-query-language/commands/...
The nominal time interval, whether coming from the bins or interval parameter, is adjusted so that:
  • The time interval matches a well-known interval (1 minute, 5 minutes, 10 minutes, 15 minutes, 30 minutes, or 1 hour)
  • The time interval does not exceed the maximum number of elements per series (1,500).
KR Henk
