08 Dec 2024 05:59 PM - edited 08 Dec 2024 07:56 PM
Does anybody know (or has a table) what all the states and transitions are?
What is the difference between active/update and active refresh?
Being in the subject what is the benefit of the dt.davis.problem.snapshot
And is there an overall (functional) description of all the tables?
KR Henk
08 Dec 2024 08:45 PM
For states and values, see semantic dictionary.
Afaik dt.davis.problems represent the actual (latest) state of problems, while dt.davis.problems.snapshots contain the history, including changes.
09 Dec 2024 08:20 AM
Hi Julius,
Thanks foe your reply, in your link I found,
Experimental show I will ignore (-;
Now I under stand that a workflow has only two triggers active and closed
Thanks Henk
04 Mar 2026 06:32 PM - edited 04 Mar 2026 06:33 PM
I do not see this referenced in the documentation. But the A.I. Assist has tried to substitute it in AI generated queries where I actually needed the dt.davis.problems table. I do agree it appears to be history+changes.
https://docs.dynatrace.com/docs/semantic-dictionary/model/davis
