DQL
dt.davis.analysis_trigger_delay - evaluation
munawarhossain3
Contributor
I've created a process availability alert and want to delay it by 1 minute.
So, I added property as (enclosed, image 1 and 2).
Now, which is the right way (1 or 2)?
How Dynatrace is going to evaluate this?
Munawar
3 REPLIES 3
AntonPineiro
Not sure how you have configured that alert, but I would add delay in the alerting profile.
Best regards
That's a common AP.
So, I cannot touch that. So, added a property on the process availability page.
t_pawlak
Leader
Dynatrace expects a time value with unit for this property: dt.davis.analysis_trigger_delay.
So:
  • 1m is valid, interpreted as 1 minute
  • 1 - invalid/ignored or treated incorrectly (no unit --> undefined behavior)
In  Dynatrace evaluates it, Davis waits the specified delay before triggering problem analysis
In your case: waits 1 minute after issue detection
If condition disappears within that time -> no problem created
This is not the same as alerting profile delay (it delays Davis analysis itself, not notifications).
