how to find max of a series of reccords
Stephen1_Lee
Guide
I can use arrayMax to return a series of records each of which is the max of an array.
But now I want the max of all these records.
max(arrayMax()) and arrayMax(arrayMax())  give an error.
Here is the final part of the DQL.
| fields arrayMax(memory)
It give me these results.
"records": [
"arrayMax(memory)": 75.25303777058919
"arrayMax(memory)": 62.775824546813965
"arrayMax(memory)": 69.83485221862793
"arrayMax(memory)": 61.2065970102946
"arrayMax(memory)": 28.884375000000002
So how to get the max of these records?
Thank you
Philipp_Kastner
Dynatrace Champion
Dynatrace Champion
Hi @Stephen1_Lee
I believe the summarize command should do the trick
| summarize max(`arrayMax(memory)`)
Kind regards,
Philipp
