14 Oct 2022
03:51 PM
23 May 2023
02:44 PM
Michal_Gebacki
I'm building a Dynatrace dashboard and I am confused about the built-in metrics related to errors.
According to the below Dynatrace documentation [1] on built-in metrics, Dynatrace offers the following error rates for use on a Dashboard:
[1] https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/built-in-metrics
The documentation is not specified about what these errors are about, therefore I am asking here in the Community forum for clarification.
My questions:
Thank you for your support!
Best regards, Bernhard
14 Oct 2022 04:37 PM
Hi @bernhard_s,
Could you please check this part of the documentation I think you will find the answers for your questions.
Configure service failure detection | Dynatrace Docs
Best regards,
Mizső
14 Oct 2022 04:43 PM
@Mizső - No, this does not answer my questions. BR Bernhard
23 Jan 2023 04:37 PM - edited 23 Jan 2023 04:45 PM
The referenced docs page referenced by @Mizső I believe does explain the difference of detected errors and how to configure them if they don't meet your need.
For example reading the explanation tells me that 500-5xx will always be interpreted as a server error. So 5xx metrics.rate is a server error while 400-4xx (yes there is a typo on that page) is a client error.
Then it also says that missing HTTP response code as client-side errors or server-side. So my naiv assumption is that 4xx is everything from 400-4xx while client side or then server-side (500-5xx), respectively can be more than just the actual 4xx or 5xx errors. E.g. when you also take missing response codes into account.
Answer to
Id therefore say yes to
And yes to:
But maybe @tom_rothschaedl can cross-check this, pls.
