Dashboarding
Dashboard: monitoring of processes
parkash12230
Newcomer
Hi Team, Is there any way we can monitor the state of process whether it is running or not from dashboard. I am not able to see any process related dashboard creation option.
alonso_decosio
Inactive
Hi Parkash, You can use something like "process count per process group". It will tell you the number of process instances that are running for a particular process group.
Thanks for this screenshot, and for the clarification, know I can search all the running process in custom chart. 🙂
