11 May 2023
10:10 AM
30 May 2023
07:34 AM
Is there any way that I can display top 10 capacity problems (in the form of table and including affected entities) in my dashboard?
As far as I know there is only a problems tile which shows number of problem.
Appreciate any feedback, thank you!
-Leona
12 May 2023 11:38 AM
Hi @leonatay,
I thnik in managed environment is not possible with the current feature set of DT, maybe in the new SaaS / grail platform you can create easily a DQL query for this.
At managed I would create a colorized top list dashboard vizualization for the required resources.
Best regards,
Mizső
