21 Jun 2018
		04:53 PM
		12 Jan 2022
		12:22 PM
		 AgataWlodarczyk
			AgataWlodarczyk
Is this an admin setting or version of the software?
I used to be able to add or delete a section on a custom dashboard. but all of a sudden I don't see section option. what is the cause for this?
		21 Jun 2018
		05:16 PM
		16 Oct 2023
		04:01 PM
		 random_user
			random_user
Hi Richard,
There have been some updates to custom dashboards in Dynatrace. You can now click and drag your mouse to select multiple tiles. You will see the option to delete the tiles selected. Also there is the new header tile under Custom charts in the Tile Catalog (i.e. when you click Add tile). This is equivalent to the old section header. Please see the following blogs where the dashboard enhancements were announced and also the forum where dashboard enhancements are discussed below
Blog - https://www.dynatrace.com/news/blog/author/roman-w...
Forum - https://community.dynatrace.com/spaces/483/dynatrace...
NJ
18 Jan 2022 06:40 PM
Current information about dashboard and charts are available on the documentation site:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/dashboards-and-charts
How to exactly pin tiles you will find under the link:
https://www.dynatrace.com/support/help/shortlink/pin-to-dashboard
