01 Feb 2019
12:41 AM
10 May 2021
07:34 AM
We work for a customer that has both DCRUM and OneAgent monitoring and their desiderata is to monitor the entire system by using just one point of view.
Did you ever shared a DCRUM dashboard into Dynatrace OneAgent? Checking documentation seems that is not possible. Also viceversa may be a good solution (share OneAgent dashboard into DCRUM).
Thanks a lot in advance
DCRUM has integration with Dynatrace and described here https://www.dynatrace.com/support/doc/nam/dc-rum-integration/unifying-dc-rum-data-with-dynatrace-saas-and-managed/ but it is not related to dashboard sharing.
Indeed, it's not full dashboard sharing, but integration goes in the direction you are looking. Common dashboard may look like in the attached picture and in two clicks from there you land on drill-down DCRUM reports with details. Screenshot shows an example dashboard we've used to demo the integration during Perform 2019.
