Metric Events: Clicking "Show in explorer" Is Not Pre-Populating Data Explorer
ASE
Advisor
When working in Metric Events, clicking on the "Show in explorer" button is no longer pre-populating Data Explorer with the relevant Metric Event values.
This just started happening recently.
Anyone else experiencing this behavior?
5 REPLIES 5
DanielS
Hello @ASE I've tried with several metric events and in my case is populated.
ASE
Advisor
Thank you for checking, @DanielS.
This resulted in a Dynatrace Support Ticket and it be identified as a bug.
DanielS
Thanks for the info @ASE good to know that this is a bug, because it may be present in some customers.
ASE
Advisor
Update: This issue has been resolved by Dynatrace Support.
DanielS
Great, you know if this is only for your tenant or if it is something more globally?
