Dashboarding
Network Traffic Metric
muhadimas
Observer
Is it possible for us to use the total sum of the metric traffic in or traffic out? We currently have a need to see the total traffic usage of our hosts for the past 30 days, and we'd like to use a dashboard tile to possibly help us, but when we tried it seemed the auto value and the sum values were the same.
PacoPorro
Dynatrace Leader
Dynatrace Leader
Yes. Using advanced mode you play with metrics expressions.
https://www.youtube.com/watch?v=a-EfiGKapKg
Dynatrace provides metrics expressions to get answers to simple and complex questions you have on your observed metrics. Metrics expressions are used to define your dashboards or extract data from Dynatrace through the Metrics API. In this observability clinic, we have Alberto Gelmi, Software ...
