09 May 2025
08:50 AM
13 May 2025
07:25 AM
Michal_Gebacki
Please share if you have the standard dashboard for synthetic monitoring browser and http monitoring.
I tried using the dashboard available in dynatrace playground for synthetic monitoring.
The json file was non compatible.
What are the metrics associated with the synthetic monitoring.
09 May 2025 12:27 PM
I would check in this tenant, not sure if it is same than "dynatrace playground".
Best regards
09 May 2025 12:55 PM
it isn't. playground is this: https://wkf10640.apps.dynatrace.com/ui/apps/dynatrace.classic.dashboards/ui/dashboards?gtf=-2h&gf=al...
09 May 2025 12:59 PM
Hi Anton
Thanks for your reply
I don't have access to this page
New dashboards or classic dashboards?
09 May 2025 12:57 PM
Hi Kenny
Thanks for your reply.
It is for the new dashboards
09 May 2025 01:21 PM
I am not seeing anything in tenants above. Try using classic dashboard and converting to new dashboard. I tried this but wasn't perfect so it would still need some work
Classic dashboard: Synthetic Monitoring.
12 May 2025 09:46 AM
@Kenny_Gillette I switched to classic dashboard and uploaded the synthetic monitoring dashboard json file
but it says incorrect json file
12 May 2025 12:44 PM
Open classic dashboard then you have to click menu and upgrade
Hope this makes sense
12 May 2025 01:14 PM
I don't see an option upgrade on the options shared above
12 May 2025 01:28 PM
Are you admin in your tenant? Are you on SaaS or Managed?
Are you admin of dashboard?
12 May 2025 01:36 PM
@Kenny_Gillette no, am not the admin,
am a user in dynatrace.
12 May 2025 01:43 PM
I believe that is why. I have attached it from my tenant. I didn't make any changes
12 May 2025 04:06 PM
Json I added was to be inputted into new dashboards. Not classic dashboards.
You should already have a classic dashboard named Synthetic Monitoring.
13 May 2025 01:05 PM
@Kenny_Gillette Thanks for the json file, it is working
12 May 2025 02:00 AM
@Arunkumarbnp Take a look at the below for the Synthetic monitoring metrics on Grail , you should be able to setup these on new dashboards
https://docs.dynatrace.com/docs/shortlink/built-in-metrics-on-grail#synthetic-monitoring
There are a couple of default dashboards that are available by default on tenants for Synthetic , take a look at them for a start.
12 May 2025 09:43 AM
Thanks for your reply. But am unable to add these dashboards to my dynatrace.
It says invalid json file.
12 May 2025 11:33 AM
@Arunkumarbnp are you importing it to Gen3 or classic dashboards? These are Gen3 (new)dashboards
12 May 2025 01:16 PM
@p_devulapalli , am looking for dashboard classic.
sorry for the confusion.
Is it possible to change the json file of gen3 dashboard compatible to dashboard classic?
13 May 2025 09:13 AM
Hi @Arunkumarbnp
You can check this Dashboard for the New dashboard, I tried it and it's working.
You’ll also find it listed under “All Dashboards” in your tenant.
https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.dashboards/dashboard/71ccee2f-d9a8-407a...
