10 May 2023 09:50 PM
Hi Team,
I try to use the oneAgentOnAHostClient SDK but get the following error from a dashboard ad-hoc function:
Similar symptom as in previous thread 210810. As an admin, I expect to be able to read information from the oneAgentOnAHostClient SDK in code tiles.
Would you know what's the blocker in that case?
Read access to this SDK would permit to inform of deployed OneAgent versions in the monitored environment and ease the preparation of OneAgent upgrade campaigns.
Thanks in advance!
11 May 2023 07:38 AM
Hi @thomas_c ,
I could reproduce this issue. The code is correct, but there are two aspects that lead to this behavior:
client-classic-environment-v1 SDK within these apps. I reported this to the team.To get your code working, you need to wait until a new version of the apps is deployed.
