Error when using the workflowClient SDK
thomas_c
Dynatrace Contributor
Hi Team!
I try to use the workflowClient SDK but got the following error:
I can create a new workflow through the WebUI, so it shouldn't be a permission issue? Is there a way I could retrieve more logs on each of those errors?
Could you help me overpass that blocker please?
Thanks in advance!
Thomas
5 REPLIES 5
stefan_eggersto
Dynatrace Advisor
Dynatrace Advisor
Hi Thomas,
I could reproduce this issue. It seems like the Notebooks app requests the wrong scope (automation:automations:read instead of automation:workflows:read). You can check this at https://<your-environment-id>.apps.dynatrace.com/ui/apps/dynatrace.hub/browse?details=dynatrace.notebooks&detailsTab=technical.
I will let you know when a fix is available.
Thanks Stefan. I could also reproduce this issue in the dashboard app.
The fix will be included in the next version of the Notebooks app.
Thanks Stefan! Could you also plan a similar fix for Dashboards please?
georg_ritt
Dynatrace Promoter
Dynatrace Promoter
Hi Thomas,
a fix for Dashboards was added and will be available with version 1.3 of the app.
