Developer Q&A Forum
Problem with using custom CSS file
Hi there,
I've installed and this module in my application:
https://github.com/react-grid-layout/react-grid-layout
Within this module I need to use a css file. Locally I can use it but when I deploy my application, the CSS file is not included. Ive already updates my Dynatrace App version to the latest versions.
My question would be: what's the best way to use a CSS file from a node_module? Locally it works perfectly, when deployed it gets ignored.
Many thanks in advance for your help!
KR.
Michiel
#Performance matter!
7 REPLIES 7
gilgi
DynaMight Champion
DynaMight Champion
Hi @michiel_otten
Seems liek you're experiencing something similar to what I'm seeing and trying to resolve as described on this thread: https://community.dynatrace.com/t5/Developer-Q-A-Forum/using-reactflow-in-an-app/td-p/226904
Gil.
Hi Gil,
I found that topic as well but unfortunately the solution there was to update the app to the latest versions.
This did not work for me unfortunately 😞
KR.
Michiel
gilgi
DynaMight Champion
DynaMight Champion
@michiel_otten ,
Still, keep track on it because I suspect it is the same issue now.
Gil.
imsingh
Dynatrace Mentor
Dynatrace Mentor
Hi there, I've been debugging this issue and there seems to be a bug in the CLI. What I can see is that, when you import a CSS file in your TypeScript/JavaScript, final build has a corresponding CSS file, however, it's not linked in HTML. Therefore, the deployed version doesn't have it.
I'll double check with the team and let you know when we have a confirmed bug.
imsingh
Dynatrace Mentor
Dynatrace Mentor
@michiel_otten can you confirm if you're using windows? I can confirm that it's a bug on windows and works on other OS. The concerned team is made aware of it and it will be resolved asap. Thanks 🙂
indeed, I'm using Windows 🙂
I'll just be patient and wait for the fix? Any ETA or is it not clear yet?
SarahFaustmann
Dynatrace Helper
Dynatrace Helper
Hi @michiel_otten,
There is currently no ETA for this issue. We've forwarded the info to the concerned team, and a fix will be included in an update as soon as possible. Thank you for your patience. 🙂
Best,
Sarah
