08 Jan 2023 05:21 PM
I've created a token to run Problem API V2 and got Error : Unauthorized how to get it resolved.
Thanks for advice and best practices to use API V2 perfectly.
08 Jan 2023 07:34 PM
Regarding to Dynatrace documentation you have to generate an access token, and use it setting "Api-Token" header with token value.
https://www.dynatrace.com/support/help/dynatrace-api/basics/dynatrace-api-authentication
09 Jan 2023 05:25 AM
Thanks @Rapidez
I've already done these steps before posting my concern.
I'll delete current token and re-validate after creating a new token.
24 Feb 2023 09:48 AM
Hi Peter,
If the token is created with the right scope and you still got this message, try to make sure that you've added the token for authorization by clicking on the lock icon, if it was not set before.
