Dynatrace Managed Q&A
Connection needs to open when using Dynatrace managed
suresh230591
Mentor
Hi I am bit confused about OneAgent communication to Dynatrace Managed server. It communicate on port 443 or 8443.
4 REPLIES 4
JamesKitson
Dynatrace Guru
Dynatrace Guru
The OneAgents will communicate with the Server Nodes over port 8443. Port 443 is used to access the user interface in your browser:
Cluster node ports
James
suresh230591
Mentor
@James K.
If I am using security gateway, Does it also communicate to server over 8443 or 443.
Radoslaw_Szulgo
Inactive
Agents communicate with Security Gateway on 9999. See the architecture diagram here:
Dynatrace Managed deployment for multiple DC
Senior Product Manager,
Dynatrace Managed expert
jan_palic
Guide
if we install a Security Gateway into our DMZ, we do not allow connections into the world.
Which connections into the word are needed? Is it enough to allow connections to port *:80 and *:443 in the wide wide internet or do we need specific connections?
Best regards,
Jan
