03 Nov 2025
12:04 PM
04 Nov 2025
07:22 AM
Hi All
If I use prometheus custom metric and the metric has 2 unique dimension, then the DPS(Metric data points) for 30 minutes is 2 (uniquedimesion) * 30(min) = 60 as per the below link.
Custom Metrics Classic (DPS) — Dynatrace Docs
Will it be the same calculation if I use the log metric also?
If I use prometheus pod, the pod sends the old data until it's restarted. Will it be the same case for log metric also?
