05 Dec 2025
10:43 AM
08 Dec 2025
06:55 AM
Im having troubles using the custom integration for problem notification when i activate the oAuth authentification.
The end point api expect the basic authentification in the header, i checked the option :
but all im getting is :
doing the same configuration in postman works like a charm. Any Help?
Dynatrace managed version : 1.326.67
05 Dec 2025 01:12 PM - edited 05 Dec 2025 01:15 PM
Are you creating basic authentication using this button?
Best regards
05 Dec 2025 07:48 PM - edited 05 Dec 2025 08:15 PM
Dynatrace does not accept an additional Authorization header if oAuth is checked.
No basic Auth header created, no aditional headers, tried with headers like: Accept and content-type but still the same issue. Also tried adding the scope but still nothing.
09 Dec 2025 09:22 AM
