Dynatrace Managed Q&A
Error 10054 for Synthetic monitoring execution - Connection reset (Dynatrace Managed)
johana_uray
Contributor
Dear,
We have configured a private location for the execution of synthetics. There are synthetics that work correctly but others that show errors 10054 - Connection reset.
When running curl from the server the following is displayed:
How can i resolve this case?
Johana
HannahM
Dynatrace Guru
Dynatrace Guru
Can you try enabling 'Accept and SSL certficate'? https://docs.dynatrace.com/docs/observe/digital-experience/synthetic-monitoring/http-monitors-classi...
Exactly - based on the log, the local issuer certificate is missing because the server does not provide the complete certificate chain required for verification.
Have a nice day!
