04 Oct 2024
03:41 PM
07 Oct 2024
07:42 AM
Dear Dynatrace Pro,
whats the navigation to get blocked query,long runnig query .
Prithvi
07 Oct 2024 11:23 AM
Hii,
Yes,I have already integrate AWS RDS on my dynatrace environment, I want to just know how can we find long running queries and blocked queries on dynatace environment.
07 Oct 2024 02:49 PM
Hii,
AWS RDS monitoring in full stack , tell me the navigation or path to get long running queries and blocked query for database.
thanks for helping.
Prithvi
07 Oct 2024 06:44 PM
As I had just said, I think you need to include code level integration to get that information.
I think you are looking or purepath / trace information.
Best regards
08 Oct 2024 08:12 AM
Hii AntonPineiro,
Thanks for your response, let me know the steps to integrate code leve with dynatrace or any suggested documents.
Prithvi
08 Oct 2024 10:58 AM
Those are in link showed before:
Best regards
