05 Nov 2019 08:50 AM
Hello based on this doc:
https://www.dynatrace.com/news/blog/define-process-group-properties-via-environment-variables-kubern...
I cannot understand how/where to insert the DT_CUSTOM_PROP on Tomcat runninx on linux System.
Do someone have already done this? Can you guide me to do so?
Thank you
05 Nov 2019 09:25 AM
If this is a standard tomcat and you are starting it with the catalina.sh startup script, just put it in the $CATALINA_HOME/bin/setenv.sh script (or create it).
Don't forget to export the variables, for example:
export DT_CLUSTER_ID=tomket1
export DT_NODE_ID=mynode1
export DT_CUSTOM_PROP=myprop=myvalue
07 Nov 2019 02:41 PM
Thank you this was the right solution for me, 9 points to gryffindor!
01 Oct 2020 12:56 PM
@Julius L. hello! I'm back here 🙂
I was wondering, do you have any knowledge on where can I do this in Apache Web Server?
01 Oct 2020 07:45 PM
Sure I do 🙂
However, it depends on your Apache Web Server distribution and how you start the apache process. Typically in Linux distributions, you will have to set it in the envvars file in your apache config directory or in the bin directory as they start it with the apachectl wrapper script.
If you start it directly by running the binary httpd, then you will have to do it in your script.
04 May 2021 10:12 AM
Hi Julius,
I'm investigating this for a vanilla installation of httpd Apache web server 🙂
04 May 2021 02:04 PM
As I wrote - it works even for vanilla installation. If you are starting it with apachectl, then you can put it into envvars file. If you are starting the httpd binary directly, then you will have to find a place where it fits you best.
04 May 2021 02:38 PM
Thank you very much!
15 Jun 2021 04:56 PM
Do we know how to implement this DT_CUSTOM_PROP on container world. We have Vmware Tanzu cloud with springboot apps and wanted to know how to implement CT_CUSTOM_PROP on every service and process.
thanks
Vinnu
