Problem: loss of firewall rules when reloading the firewalld service
patrick_romee
Observer
When our infrastructure team performs deployments for patch management the command firewall-cmd --reload is executed. The result is that all rules dynatrace in firewalld are destroyed.
Could you make the rules persistent to prevent this problem ?
Regards
Patrick
5 REPLIES 5
Radoslaw_Szulgo
Inactive
Please align with your infrastructure team to ensure ./reconfigure.sh is run after system patching. This should apply required firewall rules at the cluster node.
Senior Product Manager,
Dynatrace Managed expert
Thank you for your anwser.
It isn't possible for us we had considered this solution but given the number of customers our system team did not see to manage specificities for each of them. And
Regards
Would at least restart of the machine be possible? A restart of firewall service also recreates rules.
Yes it is, but our system team can't tell us when the reload is done so between  the reload and time when the problem is detected the cluster is unavailable even if the problem is detected rapidly  in production environement this isn't acceptable.
Regards
Patrick
Any other solution ?
Best regards
Patrick
