Dynatrace tips
PRO TIP: Monitoring Network Device Availability with NAM and DQL
uros_djukic1
Dynatrace Mentor
Dynatrace Mentor
Hi Dynatracers,
We are using Dynatrace Network Availability Monitors (NAM) to collect the availability of network devices through Ping/ICMP, DNS, and TCP checks. NAM supports ICMP, TCP, and DNS monitor types to validate the availability of hosts, devices, and services from a network perspective.
Example of Powerful DQL I use :
timeseries availability = avg(dt.synthetic.multi_protocol.request.availability),
by: {
dt.entity.multiprotocol_monitor,
multi_protocol.request.target_address,
| fieldsAdd targetAddress = coalesce(request.target_address, multi_protocol.request.target_address)
| lookup [
fetch `dt.entity.network:device`
| expand dt.ip_addresses
| fields
deviceId = id,
deviceName = entity.name,
lookupIp = dt.ip_addresses
sourceField: targetAddress,
lookupField: lookupIp,
fields: { deviceId, deviceName }
| fieldsAdd monitorName = entityName(dt.entity.multiprotocol_monitor)
| fieldsAdd deviceName = coalesce(deviceName, "No matching network device")
| fields monitorName, deviceName, deviceId, targetAddress, availability
Result :
Remark :
Reachability is the key KPI because it measures whether the target network device or service is actually reachable from the monitoring location, regardless of the underlying protocol used: ICMP, DNS, or TCP.
Reachability (%) = average availability of NAM requests over the selected timeframe
Why Ping, DNS, and TCP Are Useful
  • Ping / ICMP checks whether the device is reachable on the network.
    In simple terms: Can I reach the device?
  • DNS checks whether the device or service name can be resolved correctly.
    In simple terms: Does the hostname resolve to the expected IP address?
  • TCP checks whether a specific port is open and accepting connections.
    In simple terms: Is the expected service actually reachable on its port?
Conclusion :
Ping validates network reachability, DNS validates name resolution, and TCP validates service-level accessibility. The DQL lookup then connects these checks back to the corresponding Dynatrace network device entity.
Hope it helps,
Cheers!
0 REPLIES 0
