Dynatrace tips
Synthetic monitoring using Cloud hosted ActiveGate - Let's Keep your account secure We'll help you set up another way to verify
nareshkumarg
Participant
Synthetic monitor would fail stating the following,
Lets keep your account secure
We'll help you set up another way to verify it's you.
This prompt appears when Cloud based ActiveGate is used for monitoring where the application has content based access control.
In my case my server is hosted on Azure and it caused the issue.
To resolve this:
Log in to Azure portal
Open Virtual network
Find your application network
Expand Settings ->Service endpoints
Delete Microsoft.AzureActiveDirectory
Save the settings
Now perform ondemand test and it should work without prompting the issue.
Microsoft support link: https://learn.microsoft.com/en-us/azure/virtual-network/virtual-network-service-endpoints-overview#l...
HannahM
Dynatrace Guru
Dynatrace Guru
That's very helpful. Thanks
