Join this 60-minute session led by a Dynatrace expert to learn how to configure your log monitoring in Grail™, Dynatrace’s powerful data lakehouse.
Whether you're on an earlier Dynatrace Log Monitoring solution or are considering migrating your observability logs from another tool to the unified Dynatrace Platform, this session will show you how easy it is to get started, so you can leverage the power of Grail™ and Davis® AI to simplify troubleshooting and reduce your MTTR.
We’ll show you how to:
Ingest Kubernetes logs to troubleshoot cluster issues fast
Ingest infrastructure logs with OneAgent, OpenTelemetry, or API
Use OpenPipeline to route the right data to the right teams
Use pipelines to process and transform your data, driving efficiency and security
Store your logs to improve query performance and reduce costs
