28 Feb 2022
08:07 PM
17 May 2023
11:10 AM
Michal_Gebacki
we have using the MQ ActiveGate configured on our custom device configs to check the box for Auto Alert on DLQ messages, Auto-Alert on Retry channel status, and Auto-Alert on high queue depths.
But when I triggered a message to go to the Sys DLQ, trigger a channel, retry, and (finally) trigger a high queue condition, nothing seemed to register for the device.
Is there some other setting (in MQ, perhaps?) that we may have missed for these to work?
28 Feb 2022 09:33 PM
Hi Larry,
From what you are saying it all sounds properly configured.
Could you open a support case for it so they can take a look at your logs, etc.?
Diego
24 May 2022 09:38 AM
Hi @Larry_S, have you eventually opened a support ticket to this case? Or maybe have you found another way to find a solution?
24 May 2022 12:45 PM
Hi, Michael-
Our Dynatrace team did just that and they "magically" resolved the issues with the "auto alerts". Unfortunately, I was not made aware of what Hogwarts thing occurred.
