Extensions
Can I monitor Azure SQL (unmanaged)
Naserati
Visitor
Is there a way to monitor an unmanaged Azure SQL Server database? I see no option for extensions in Azure SQL. And in setting->...->supported technologies I see MS SQL but it doesn't mention Azure. Please advise.
Thank you.
ChadTurner
DynaMight Legend
DynaMight Legend
Dynatrace covers a bunch of SQL instances for Azure: https://www.dynatrace.com/support/help/how-to-use-dynatrace/infrastructure-monitoring/cloud-platform...
Azure SQL Servers (Built in)
Azure database for MySQL
Azure database for PostgreSQL
Azure SQL Data Warehouse
Azure SQL Hyperscale
Azure SQL Managed Instance
-Chad
