Extensions
Control on feature sets metric in Extension
JyothiSwaroop
Frequent Guest
Hi Team,
Metrics in extensions 2.0 are often grouped into Feature Sets. We can only enable/disable the whole feature Set, but there is no option to pick single metrics and turn it off.
If we have an option to enable or disable it on a metric level, it will help us save our license.
Can you please have this option in coming releases.
Br,
Swaroop
AntonPineiro
You can vote this product idea.
Best regards
MostafaHussein
Champion
there's a workaround for now until Dynatrace team respond to this great Idea that you modify the `extension.yaml` file and make your own feature set that include all the desired metrics then redeploy it and upload it as a custom extension but disadvantages of this method is that you'll need to update your extension with each update coming from its vendor.
BR,
Mostafa Hussein.
Certified Dynatrace Professional | Certified Dynatrace Services - Observability | Certified Dynatrace Services - App Developer
Dynatrace Partner 2p.com.sa
