13 Dec 2018
08:41 PM
18 May 2023
05:01 PM
Michal_Gebacki
I'm working on a plugin to monitor an unmanaged network device.
I have it all working by assigning the end point as the proxy IP represented by service flow. However, I just recognized that often I'm getting a downstream device's ip in service flow rather than the devices I'm actually wanting to monitor.
I can work around this by just assigning the downstream address but now I'm seeing that several of my devices are passing through the same downstream and dynatrace is picking up this address.
Do I have any options of distinguishing these from each other? Am I able to designate the destination host IP anywhere?
14 Dec 2018 10:23 AM
Hi Scott,
Alas that isn't a feature yet. Post a note about it in the RFE forum.
Kind regards,
Mike
