Extensions
Davis AI alert for SQL extension 2.0 metric data on Application process group
Sachinpai
Guide
We are using Oracle SQL extension to ingest metric to Dynatrace. Planning to use Davis AI Annamolly detection to create alert/problem. Our requirement is to create the alert on Application process group rather than creating problem on DB host group.
Context: DB data represent some issue with Application (not DB).
Mike_L
Dynatrace Guru
Dynatrace Guru
Please raise it as a product idea, this would require some changes to how Dynatrace builds up and correlates topology.
Mike
