Extensions
Extension 2.0 and process group detection
We are currently migrating our custom extension from 1.0 > 2.0 and we have a bit a challenge with some of the extension. So it seems that in version 1.0 there has been some custom python module made by Dynatrace which has had some automatic model how to fetch the process group ID automatically.
I suppose that the functionality has come with these modules.
from ruxit.api.exceptions import ConfigException
from ruxit.api.base_plugin import BasePlugin
from ruxit.api.snapshot import command_line_regex
from ruxit.api.snapshot import pgi_name
from ruxit.api.selectors import ExplicitPgiSelector
And it has been used someway like on this example:
pgi = self.find_single_process_group(self.check_technology("Varnish Cache"))
pgi_id = pgi.group_instance_id
Is there any similar premade functionality with extension 2.0 if we would like to attach the fetched metrics on some process itself?
Peter_Youssef
Leader
Hello @janne_olkoniemi
You can refer to the attached Dynatrace documentation resources for detailed level of info:
All the best,
BR,
Peter
Dynatrace provides you with a framework that you can use to extend your observability into data acquired directly from your SNMP-monitored devices. In addition to out-of-the-box support for F5, Generic Network, Cisco, Juniper, Palo Alto, and others, you can also create your own SNMP Extension ...
arnauddc
Visitor
Hello Janne,
Did you find a solution to replace find_single_process_group in 2.0 ?
Thank you already,
Arnaud
