Extensions
Extension 2.0 : report_metric doesn't work.
Sullivan
Participant
I am having an issue with my 2.0 extension, and I am uncertain as to why.
This is part of my python script :
                    for item in csv_reader:
                        affiliate = item.get("context.organization.#Affiliate", "empty")
                        employees_with_usage = item.get("employees_with_usage", 0)
                        # Validate employees_with_usage is an integer
                        try:
                            employees_with_usage = int(employees_with_usage)
                        except ValueError:
                            self.logger.error(f"Invalid value for employees_with_usage: {employees_with_usage}")
                            continue
                        # Ensure metric key format
                        metric_key = 'custom.metric.test'
                        # Prepare dimensions with proper escaping
                        dimensions = {'affiliate': affiliate}
                        try:
                            self.report_metric(metric_key, employees_with_usage, dimensions)
                        except Exception as e:
                            self.logger.error(f"Failed to send metric {metric_key} for affiliate {dimensions['affiliate']}: {str(e)}")
                self.logger.error(f"An error occurred: {e}")
I don't have errors, can you explain me please ?
3 REPLIES 3
AntonPineiro
Have you check logs?
Best regards
Julius_Loman
DynaMight Legend
DynaMight Legend
Do you see values when you run the extension in the simulator?
Are you 100% sure the the self.report_metric is called?
Sullivan
Participant
I deleted my extension, rebuiled it, and it worked. Thank you for your help.
