11 Oct 2024
07:45 AM
16 Oct 2024
06:57 AM
I migrated a custom python v1 extension to v2.
I uploaded the zip file to my dynatrace tenant. When adding a configuration to this extension, I see in the logs the following:
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3080585][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081087][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3081627][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082136][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3082650][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3258][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][3831][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4397][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][4970][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][5534][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6098][err]ModuleNotFoundError: No module named 'requests'
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err]Traceback (most recent call last):
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 196, in _run_module_as_main
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] return _run_code(code, main_globals, None,
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] File "/opt/dynatrace/remotepluginmodule/agent/res/dsruntime/python3.10/lib/python3.10/runpy.py", line 86, in _run_code
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] exec(code, run_globals)
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] File "/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_nonauthhealtcheck_0.0.1/lib/python3.10/site-packages/nonauthhealtcheck/__main__.py", line 6, in <module>
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err] import requests
[e077de86-437c-3279-aebf-9018a207bb2a][f_-7887671099770936204][6664][err]ModuleNotFoundError: No module named 'requests'
in the setup.py
So can somebody explain me what I am doing wrong?
14 Oct 2024 10:43 AM
Hello @jannickdeturck,
add requests to requires:
install_requires=["dt-extensions-sdk","requests"],
also check that you are compile your extension to same operating system. If not you need to add extra flag to your build command:
dt-sdk build --extra-platform manylinux2014_x86_64
dt-sdk build --extra-platform win_amd64
Building Extensions — dt-sdk 1.0.0 documentation (dynatrace-extensions.github.io)
Best Regards
