High CPU usage detected for python datasource running configuration 3fb4e1a6-fc85-3813-809d-b058de039a37. Restarting
RobertDring
Visitor
We are having high CPU usage on one of our extensions resulting in failed overnight ingestion.  What designates higg CPU usage on an extension, and what % is high ?
check the code and see the recursive functions you've it may because of infinity recursion or processing big data records without limitation statements or chunking it.
Certified Dynatrace Professional | Certified Dynatrace Services - Observability | Dynatrace Partner yourcompass.ca
Mike_L
Dynatrace Guru
Dynatrace Guru
Here is the information about what the limits are for extensions: https://docs.dynatrace.com/docs/extend-dynatrace/extensions20/extensions-concepts#ag-performance-pro...
Mike
