07 Aug 2019
02:49 PM
28 Jun 2021
12:35 PM
Hi, I need to monitor:
I have reading the documentation, forum... and now I would like to know how to do it via JMX editor (if it's really possible) or if there are other possible way, or, where I can find more information about it.
07 Aug 2019 04:28 PM
As I remember those processes are not monitored on transaction level. But if there are exposed JMX measures that are not available by default in Dynatrace for those processes you can search through available mbeans using JMX editor to find measures you need. It’s pretty simple task. Remember that you need full stack monitoring on host to enable JMX plugins 🙂
07 Aug 2019 05:51 PM
Sure. Thank you, Sebastian!
