10 Mar 2023
05:13 PM
13 Mar 2023
07:43 AM
Hello all,
Does Dynatrace support monitoring for IMB eXtreme Scale processes, specifically cache monitoring? Or would it be possible with an extension?
We don't have an existing extension for it. I had a look around and it seems like it supports PMI though, so all you'd have to do is to drop a OneAgent on the box and use the JMX wizard to select the metrics you want to have in Dynatrace.
