12 Oct 2018
08:40 AM
19 May 2023
06:43 AM
Michal_Gebacki
I need to configure JMX monitoring for Wildfly JBoss but don't see any out of the box plugin on Dynatrace SaaS. Please advise on how can we get the configuration done for Wildfly monitoring using Dynatrace?
24 Jul 2020 02:41 PM
You can always define custom processes for detection that is not showing out of the box. You can also look at passing data via the API into Dynatrace. Dynatrace also might have a custom plugin for this already and if not, and your organization deems this monitoring as critical, Dynatrace can build a custom plugin for you.
