28 Jul 2026 09:36 AM
Hi team,
We noticed the following in the Kafka version in use (2.5).
In Dynatrace, the metric is displayed as:
legacy.kafka.kafka.network.RequestMetrics.RequestsPerSec.FetchConsumer.OneMinuteRate.request
However, in the extension documentation, it appears as:
Could this difference be related to the deprecated Kafka version, or is there another reason why Dynatrace is reporting the metric with the legacy.kafka prefix and the additional .request suffix?
They are using EF2 and the only available metric is the legacy one.
They also don't seem to have any custom EF1 JMX metrics.
Thanks in advance!
10 Aug 2026 04:00 AM
Hi @elenaperez
I'm not sure whether this has been resolved yet since this is a bit of an older post, but here is my two cents on the issue:
This behavior is typically not related to Kafka 2.5 being deprecated. When Dynatrace captures JMX MBeans via the legacy JMX plugin framework (EF 1.0) rather than through the new EF 2.0 engine, it prepends legacy. (or legacy.kafka.) to avoid metric key collisions with Extensions 2.0. If EF2 isn't receiving or binding to the expected MBean attributes directly, the backend falls back to reporting the legacy metrics captured by OneAgent.
The .request suffix is appended by OneAgent's legacy JMX metric generator when converting counter attributes or multi-value composite data structures into standalone metric keys.
Sujit
