26 Nov 2025
12:50 PM
01 Dec 2025
01:27 PM
Ana_Kuzmenchuk
HI
is there is a limitation with monitoring Oracle Fusion, and is it possible at the first place as i didn't found anything regarding it
ESLAM
26 Nov 2025 02:22 PM
What do you mean? Can you provide more information about this?
Thank you!
Best regards
11 Dec 2025 01:30 AM - edited 11 Dec 2025 01:31 AM
Hello @IslamEsmail
18 Mar 2026 03:38 PM
Hi Sujit,
In case to monitor the Oracle Fusion SaaS application, I believe by enabling the JVM configuration with in application itself enables one step of collecting application level data. Also with just oracle extension plug there are limitations to monitor entire stack, will there be a consideration with in Dynatrace to build out of box scenario to enhance the monitoring but not being restricted and limited with what currently is being offered by Dynatrace?
Because our org is trying to leverage option to monitor Cloud stack using Dynatrace with out limitations and restrictions.
Your response will be helpful in planning things.
Regards
18 Mar 2026 09:33 PM
Hi @avinashmaddu,
