18 Dec 2023 06:20 PM
Hi, we have deployed the MSSQL Extension running from an Activegate group running on Linux. Using the Basic Authentication method it can connect to the MSSQL instance ok. I do see there is an option for using NTLM. Will NTLM authentication work ok from a Linux Activegate to the MSSQL instance? Or does the Activegate need to be run from Windows for NTLM to work?
19 Dec 2023 01:51 AM
We have Linux ActiveGates and use NTLM for this extension with no issues.
20 Dec 2023 01:50 PM
Thanks for confirming. That helps!
22 Feb 2024 06:46 PM
Hi @sivart_89
How did you set the user?
or
Thanks in advance.
Best regards,
Mizső
22 Feb 2024 06:51 PM
@Mizső we are specifying only the account name such as <user>, no domain or anything else.
22 Feb 2024 06:54 PM
Hi @sivart_89,
Maybe it is a stupid question but the user was a domain user or a local user on the MQ SQL server?
Thanks in advance.
Mizső
22 Feb 2024 06:58 PM
Ahh good call. Per our MS SQL DBAs it is a sysadmin account on each SQL server. Based off that I don't believe it is a domain account
22 Feb 2024 06:59 PM
Hi @sivart_89,
Thanks for your swift response.
Best regards,
Mizső
