10 Apr 2025
		10:47 AM
		14 Apr 2025
		08:22 AM
Does Dynatrace have an extension purely for Cisco ISE?
I see Splunk (yes, blasphemy 😄 ) has this Youtube which explains quite well how to install their monitoring app for Cisco ISE but was hoping their was something much better by Dynatrace.
I know in Extensions there is Cisco devices but wanted something like this with good clear instructions on how to best achieve monitoring on the ISE devices.
10 Apr 2025 02:56 PM
I do not see specific instructions on Hub. I would say no extension purely for Cisco ISE.
Best regards
10 Apr 2025 10:21 PM
Well, Splunk is now a Cisco company, so it makes perfect sense that it could monitor Cisco ISE.
10 Apr 2025 10:25 PM - edited 10 Apr 2025 10:27 PM
In minute 18:30 they send ICE Syslog to Splunk, you also can do this with Dynatrace. I leave you the link. https://docs.dynatrace.com/docs/analyze-explore-automate/logs/lma-log-ingestion/lma-log-investion-sy...
From that point much more of what is explained can be do it also with DQL.
13 Apr 2025 02:13 PM
Hi @tabpws,
We had this use case for Cisco ISE Monitoring and created our own 2.0 extension via SNMP datasource.
