17 Feb 2025
07:23 AM
13 May 2025
10:11 AM
Hii,
We have configured Oracle Database connection to monitor Oracle DB. Hence I want to monitor db connection metrics.
But it is not available through this extension.
Please suggest the way to get db connection.
Prithvi.
17 Feb 2025 07:54 AM
Can you provide more information? I do not understand your issue.
Best regards
17 Feb 2025 08:38 AM
Hii @AntonPineiro ,
Actually I want to monitor Oracle DB connection .
My question is How can I monitor Oracel DB connection in Dynatrace
17 Feb 2025 10:57 AM
If you get metrics, your connection is working fine.
Best regards
17 Feb 2025 04:48 PM
Hii @AntonPineiro ,
for your information , I have successfully configured oracle DB extension , But I want to monitor database connection count , which is not available by extension.
In case of MySql plugin , current DB connection count defined, But how can I get for Oracle DB extension also.
Best Regards,
17 Feb 2025 05:41 PM - edited 17 Feb 2025 05:41 PM
You can raise a product idea about it.
Or creating your own extension for creating your custom SQL queries.
Best regards
17 Feb 2025 08:16 PM
If you have JVM 11 or above, you can get the data from the Connection Pools.
From Oracle, you can get that data by a script and then upload it to Dynatrace. Have a working case where it has been very helpful! And you can even dimension it by several values, including for instance user.
