30 Dec 2024 08:40 AM
it will be good and practical if you give us the opportunity to check and uncheck specific metrics from the Main box like I don't want queries for the last two to be re-directed to the database at all:
30 Dec 2024 08:58 AM
You can download and customize the extension to adapt it to your needs.
https://docs.dynatrace.com/docs/shortlink/extensions-concepts
30 Dec 2024 09:46 AM
so if I only want to have those check boxes as I want - I should develop my own extension - is that what you are saying?
Because currently I am using an Oracle Extension and this limitation is what I don't really like.
I don't have in enabled state those two metrics from Anomaly detection - basically I don't need them to be monitored or to receive any alerts from them and that is why in first place --> I don't want those queries to be executed on the database and in order this to happen I need to uncheck them in my configuration but I can't do that now unfortunately.
30 Dec 2024 10:18 AM
This option is available if you need a quick solution. You don't need to start from scratch as you can definitely adapt the current extension to include those queries as a FeatureSet or remove unnecessary queries to fit your use case.
If you're not comfortable modifying the extension yourself, you can wait for the extension team to review the product idea.
30 Dec 2024 11:20 AM
Yes. And you can support this product idea to avoid develop your own extension.
Best regards
